Unter Linux lassen sich APRS Baken recht einfach mit Beacon(8) aussenden.
Manual:
BEACON(8) Linux System Managers Manual BEACON(8)
NAME
beacon - transmit periodic messages on an AX.25 port.
SYNOPSIS
beacon [-c ] [-d ] [-l] [-m] [-s] [-t interval] [-v] port "message"
DESCRIPTION
Beacon transmits the message text on an AX.25 port every thirty
minutes. The message is addressed to "IDENT" and is sent using the
AX.25 callsign of the port specified on the command line. Typically the
message text will contain spaces and/or other characters,
therefore the message text should be enclosed in quotes to ensure they are passed to the beacon program untranslated.
OPTIONS
-c Configure the source callsign for beacons. The default is to use the interface callsign.
-d Configure the destination callsign for beacons. The default is "IDENT".
-l Enables the logging of errors to the system log, the default is off.
-m Changes the destination address to "MAIL" and sends
the message text once only. This option overrides any destination
callsign given with the -d option.
-s Sends the message text once only.
-t interval The time interval between messages, the interval is given in minutes and the default is thirty minutes.
-v Display the version.
SEE ALSO
ax25(4), axports(5).
AUTHORS
Alan Cox GW4PTS
Jonathan Naylor G4KLX
David Brooke G6GZH
Linux
10 February 1997
BEACON(8)
lines 1-42/42 (END)
16.09.2007 Marcus, DL1MH
